BUG : Output instruction not written in .src file
Started by Xylotica, August 17, 2016, 12:51:16 PM
Hi !
I have updated my 2D cutting definition to integrate the I-O s of my plasma cutter.
Just to be sure that the output which triggers the plasma is "OFF" or "False" at the start of the program, I have added a command from the "Set digital" component at the very beginning of the command stack.
Sadly, this does not seem to register in the .src file (see attached).
Cheers
Thanks for letting me know, I'll look into that. In the meantime, you can use the Reset IO State option in the Code Generation settings! Or alternatively create a custom KRL pattern where you set your output at the beginning.
joaocosta
Has this issue been resolved?
I'm experiencing the same problem: digital outputs won't show up in the .src file.
Am I missing anything?
IOs start with a state of OFF, so an additional OFF will not register.
You can override this behaviour by using a Custom-KRL component instead with e.g.
$OUT[1]=TRUE
