Author Topic: Orient input for 3DPrint Component  (Read 781 times)
mra4
    • Berne University of applied sciences
« on: April 27, 2017, 03:45:01 PM »
Hi Johannes and all others,
I try 3D-Printing with KUKAprc. I'd like to use the 3dP(print) component to convert gcode from a slicer to krl. Seems I'm doing something wrong at the orient input. I understand that it expects a point. So I used "construct point" to generate a point from XYZ. Put when I connect the constructed point the 3dp component turns from orange(missing ORIENT input) to red ("1. Solution exception:Input string was not in a correct format.". Tried with a panel "100,0,0" (point without brackets). Any hints how to set orientation?
Thanks, Stefan
Re: Orient input for 3DPrint Component
« Reply #1 on: April 27, 2017, 06:20:49 PM »
Hello Stefan,
Most likely the error refers to the g-code itself. I've attached an example that works so you can give it a try. Unzip it first, of course!
You may need to select a different post processor. If the syntax looks identical, try opening it with a text editor and deleting everything except 100 lines or so from the middle.
