Author Topic: Rotatory table example  (Read 947 times)
ufaforwork3
« on: September 07, 2017, 01:54:05 PM »
Hi
Could you please upload an example using a rotatory table please?
i cant figure out how to use kuka prc component
Thank you so much
« Last Edit: October 09, 2017, 05:49:18 PM by Johannes @ Robots in Architecture »
Re: Rotatory table example
« Reply #1 on: September 07, 2017, 06:52:18 PM »
The rotary table component is only available in the member version. Are you a member through your institution? In that case I can unlock the account for you.
Basically you plug your robot into the rotary table component, and then the output of the rotary table into the Core component.
To program external axis values, you can right-click movement components and select the option to show the additional inputs.
Let me know if that helps, if you still have problems I can throw together an example once I'm back at the office.
