Author Topic: How to run an iiwa with prc?  (Read 791 times)
werk5
« on: September 27, 2017, 12:41:23 PM »
I am  currently setting up an iiwa 7 with sunrise OS 1.11. Everything is looking good so far, jogging works fine and the test programs run in T1. Network connection is set up via X66. I also installed Sunrise Workbench and made sense of AMF PSM and PSM and how to synchronize the Project.
Now I am asking myself how to make a Robot Application out of the *.xml file that kuka|prc generates (for a 6-Axis kuka, it would be a *.src). Can someone post a general workflow how to proceed with the data? Do I need to parse the *.xml in the java code? Or do I just send the *.xml via network and how?
Help is very much appreciated,
Rafael
« Last Edit: September 29, 2017, 08:14:12 AM by werk5 »
Re: How to run an iiwa with prc?
« Reply #1 on: September 29, 2017, 07:23:42 PM »
Hello Rafael,
I'm sorry for the late reply, I just came back from my holiday!
To read the XML files you need a custom Java library that we provide to members.
I'll send it to you once I'm back in the office.
werk5
« Reply #2 on: September 30, 2017, 01:17:34 PM »
I hope you had a fantastic holiday. And brilliant, thank you very much! That was one of my wild guesses, so I send you a request for the library via email some days ago.
Looking forward to hear from you!
Rafael
« Reply #3 on: September 30, 2017, 03:07:14 PM »
Hello Rafael,
I should have worked through my eMails in the other direction ;)
benkleiman
« Reply #4 on: March 01, 2018, 12:09:12 AM »
I am having the same difficulty. How do I transfer the .src to the iiwa?
Thank you!
Ben
« Reply #5 on: March 01, 2018, 04:55:08 PM »
*.src files are KRL, which is not compatible with KUKA|prc. KUKA|prc generates XML files, for which we then provide a custom library to read them at the robot.
This feature is only available in the member version, though!
