Author Topic: Work Holding for Foam and Timber  (Read 1083 times)
corey
« on: October 05, 2017, 05:46:53 AM »
Hello, Just wondering how other people usually hold their foam and timber when milling with a robot?
We discovered if we clamp material down, the clamp will create a lot of interference, but if we simply fix from the bottom with screws, they will move laterally (especially with foam).
Does anyone have a general solution for most of the material or it's a case by case issue that every time we do something different we have to think of a unique work holding solution?
Re: Work Holding for Foam and Timber
« Reply #1 on: October 05, 2017, 10:19:19 AM »
Vacuum tables are awesome, and can be as simple as a vacuum pump and loose rubber tubing on the edge of your workpiece.
And of course double-sided tape, the one with fabric reinforcement - though that won't solve the issue with lateral movement.
Finally for foam there are needle grippers, which are pretty nice, too!
corey
« Reply #2 on: October 12, 2017, 06:18:12 AM »
Thank you Johannes! You are the best! I will try designing a rig for max flexibility!
