Author Topic: WISH : Analysis - Null Axis values if out of range  (Read 146 times)
Wall-E
« on: September 19, 2018, 06:04:00 PM »
I wish that the Analysis output for Angles were null for each axis which is out of range.
This would allow to make custom axis value displays as in the attached, but with a specific warning for the relevant axis.
Re: WISH : Analysis - Null Axis values if out of range
« Reply #1 on: September 19, 2018, 06:59:56 PM »
For me the problem with NaN or null is that it doesn't tell you if it's exceeding the range in positive or negative direction.
We already provide the Reachability output in the Analysis component - doesn't that do the job?
You could just replace the axis values with NaN based on that output, if you want to.
Wall-E
« Reply #2 on: September 19, 2018, 07:27:33 PM »
Hmmm...Reachability....
I failed to understand why there are 10 values, and why they are either "All zeros" or "All ones", so I dismissed the idea.
« Reply #3 on: September 19, 2018, 07:50:03 PM »
I'll look into the all 0/1, but the ten values refer to a maximum of 10 axes, 6 + 4 external ones.
Wall-E
« Reply #4 on: September 19, 2018, 09:07:55 PM »
Ah, OK, I learned something here.
To illustrate the "All zeros" or "All ones"... see attached
« Reply #5 on: September 20, 2018, 10:02:00 PM »
Hmmm... I wasn't able to replicate that, see the attached screenshot.
It may be that your position is completely out of range, i.e. unreachable, no matter the axis limit? Like e.g. when you put a position 10.000mm away from the robot's center.
Wall-E
« Reply #6 on: September 20, 2018, 10:24:58 PM »
Nope, I can see that I have an angle value for A1, but still get all Ones.
Moreover, why would I have values for axii 7 to 10 since I haven't used them ?
« Reply #7 on: September 20, 2018, 10:51:19 PM »
Here's an example to illustrate it.
The first PTP and LIN positions are outside of the A5 reach, so that A5 is 1. The next position cannot be reached at all, which is why all axes are at 1. The axis value that you are getting is only the (more or less) maximum extension so that you can see where the unreachable position is located at. I believe that's better than just having the robot disappear when there is no mathematical solution.
