Array a set of commands
Started by Xylotica, November 17, 2023, 01:58:13 PM
How could I repeat a set of commands in a rectangular array ?
If I use the rectangular array component it creates in fact not one transformation but as many as there are elements in the array, therefore the "Transform Command" component from KUKA|prc complains that there's multiple commands AND multiple transforms...
Aren't robots and Grasshopper meant to ease repetition ?
That sounds like a date tree mismatch. I can only comment on the "Transform CMD" component, which accepts a list of commands and a list of transformations. You either need to provide a single transformation that is then applied to all commands, or the same number of both transformations and commands, so that every command is transformed individually.
