Turntable with 3D curve
Started by OXIDO, March 26, 2024, 03:43:08 PM
OXIDO
Hello everyone,
We are looking for a solution in which we use the turn table to always make sure the work layer is parallel to the ground. I have managed to get the angles for E01 working but getting the angles for E02 is the problem..
I have placed the problem in a red group inside the Grasshopper file. Hope someone has a solution.
Spiral curve align.3dm
3D curve.gh
Here's an example that I put together.
Personally, I would expect several edge cases that are not covered by my simple definition, but hopefully, it will help you with your definition!
OXIDO
Yes, with a little bit of orientation, the definition works perfectly.
Ojas
