analysis component
Started by francis, May 21, 2016, 08:35:48 PM
francis
Hi Johannes
Another stuff I don't understand...
When I connect the analysis component to Kukaprc Core, it stays grey if the radio button "output analysis value" is unchecked (normal), but it turns red when the button is checked, with no output ("solution exception, index out of range ; must be non negative etc. etc.") ; I specify that the Kukaprc Core remains grey, with no unreachable position
best
francis
Hello Francis,
That sounds like a bug, can you send me the file via eMail?
