Author Topic: Simulate multiple robot kinematics using kuka prc plugin in grasshopper  (Read 4910 times)
Aditya_Tognatta
I was wondering if there is a way to simulate 2 or more kuka robots  simultaneously.
something like this:https://www.youtube.com/watch?v=5ptdaimTdOc
Yes, the full version of KUKA|prc supports RoboTeam, which is the KUKA software for synchronized robots. There are currently two way to synchronize robots, you can either instruct the robot to wait for the other robot, or you can tell them to perform a movement synchronously. For example, RMIT uses it with their cooperative Agilus robots.
You can also stream commands through mxAutomation to multiple robots, however then by default their are not linked.
DReAM-FabLab
would it be possible to share an example setup for roboteam in PRC?
studying the configuration setup for the robots in the lab
Sure, here's a simple example I found on my disk!
Knight
Re: Simulate multiple robot kinematics using kuka prc plugin in grasshopper
« Reply #4 on: September 11, 2019, 10:20:57 PM »
I use a full license(university), but it seems the component, "Robo Team Move sync Kuka Prc" is missing when i open the above example files!!! Is this missing component the same as the "Synchronise component" in PRC? If they are the same, can you please update the examples? I also do not know how to use the "Synchronise component" !
« Last Edit: September 11, 2019, 10:53:01 PM by Knight »
« Reply #5 on: September 12, 2019, 09:07:30 AM »
Yes, that's the new version. Just make sure to provide the same number of synchronization components to both robots.
What example are you referring to?
Knight
« Reply #6 on: September 12, 2019, 01:43:37 PM »
Could you please share an example for the new synchronise component?
Regards
« Last Edit: September 12, 2019, 02:47:56 PM by Knight »
« Reply #7 on: September 12, 2019, 10:08:37 PM »
Sure, here one robot waits for another. You need to move the slider when you open the file for it to show up.
In order to have synchronized robots, both CORE components need to have finished their calculations once.
Knight
« Reply #8 on: September 14, 2019, 05:07:57 PM »
Thanks a lot for the example files. I will give it try.  :)
