Example: Custom Robot
Started by Johannes @ Robots in Architecture, August 27, 2013, 07:45:21 PM
NOTE: This example uses an older version of KUKA|prc!
Title: Custom Robot
Level: Basic
Description: Implementing a custom robot model into KUKA|prc
Requirements: Rhinoceros 5, Grasshopper 0.9.0072, KUKA|prc
rmoscoloni
#1
Hi Johannes, how are you?
i dont understand some of the behavior in this example. as loaded robot has first arm pointing up (i suspected a02=0° in this position orange robot), but after selected all the meshes and setting the start position to (see pic) the robot takes the horizontal position.
This became a problem with axis settings when a02 has a limit of the kuka sheet.
Could you give me some pointers of what to do with axis limits?
regards
rck
KUKA provides robots geometries in the robot's standard home position, i.e. 0/90/-90/0/0/0. So you also have to provide the meshes in that position.
If you set the axis values to 0/0/0/0/0/0 then the robot will look as in your screenshot (which is correct).
There is not need to "zero" the axes when using a robot, as e.g. in older CNC machines!
rmoscoloni
hello johannes, many thanks!
Its so clear now, i was trying to figure this out.
Many questions to come.
Regards
rck
Excellent, always happy to help!
