Hello Mark,
Thanks a lot for the suggestions!
You can actually right-click every robot component and set A6 to infinite - we often use it like that as well!
Regarding the frames: Internally we only calculate with the transformation from the initial, base posture of the robot (and its meshes) to the calculated position. So the frames are not necessarily "inside" the robot mesh. Would that work for Fologram?
