Does that mean that you want to implement a system with three linear axis?
Basically that is possible, however it will be a bit tricky to implement.
E1-E4 are the external axis. For a linear axis you would provide millimeters, for a rotary axis degrees.
If you can specify more closely what you need, I can make an example for you. A sketch would be best.
