Author Topic: Dual External Linear Axes (X, Y)  (Read 1106 times)
zhipeng lin
« on: March 19, 2020, 05:28:30 PM »
Hi all
I am working on how to make KUKA move on the liner trail.  the movement includes X-axis, Y-axis and Z-axis. it means I would like kuka can work more far away.
I am confused with the E1-E4. how it works and how to set data for external axes.
if there are tutorial or examples for my reference that would be great!
kind regards.
« Last Edit: March 20, 2020, 11:05:30 AM by Johannes @ Robots in Architecture »
Re: external liner trail for complex movement
« Reply #1 on: March 19, 2020, 05:36:25 PM »
Does that mean that you want to implement a system with three linear axis?
Basically that is possible, however it will be a bit tricky to implement.
E1-E4 are the external axis. For a linear axis you would provide millimeters, for a rotary axis degrees.
If you can specify more closely what you need, I can make an example for you. A sketch would be best.
zhipeng lin
« Reply #2 on: March 19, 2020, 06:13:04 PM »
Hi Johannes
thank you for reply!
attch is my sketch hope you can understand
great regards
« Reply #3 on: March 19, 2020, 06:14:46 PM »
So that would be two external axis in X and Y?
zhipeng lin
« Reply #4 on: March 19, 2020, 06:23:54 PM »
yes
« Reply #5 on: March 20, 2020, 11:04:48 AM »
It's relatively straightforward to set up, please see the files below. Note that you need a member version for it to work.
