I am seeing a disconnect between the simulation and the movement of the IIWA movement when attempting to draw multiple circles.
When creating a CIR movement on the IIWA, my recollection of the proper point order to pick is start (point 1), end (point 2), aux point (aux point).
In Kuka PRC, if I input that point order, the simulation does not show the correct movement, but if I input the points as start (point 1), aux (aux point), end (point 2), the simulation looks correct.
On the robot, the opposite happens. If I input the points as start (point 1), aux (aux point), end (point 2), the robot back tracks when repeating the arc movement to form circles. If I input the points in the order start (point 1), end (point 2), aux point (aux point), the robot moves correctly.
