Hello again,
we have the following updates:
1. related to the software issue with WoV 5.0.5.: Its seems, that the specific laptop (windows 10) has a problem to run WoV correctly. We've installed a virtual machine running Win7, and both programs run correctly. The IOConfiguration.vws can be opened and I/Os can be mapped. For now it works, but obviously not the finest solution.
2. The SYS X44 error stays after synchronization. The field buses of the FlexFellow platform still produce the error. The pre-wired Beckhoff EtherCAT bus looks correctly wired, however on the attached nodes (A1: EL9188, A2: EL9189, A3: EL1809, A4: EL2809) seem to show no response. Also, the ethernet cable coming from X65 from the cabinet has no signal light on the socket of the EtherCat.
Do you know what to do? Thanks!
