I had a look at your file, something that's important to consider is that KUKA|prc provides an "optimal" simulation and does not simulate the motion blending and possible performance challenges of your robot controller.
In your file, you have got very closely-packed positions that are connected via PTP movements. It might just be, that the robot never even reaches the 100% speed due to point density - that would explain why you don't see a significant change in speed.
If you are worried about the robot ignoring the speed settings for some reason, try some much wider spaced points and see if it improves!
