Hi All,
I have a question regarding the use of non-standard motors for external axes. The motor must have a 40 mm frame side (i.e motor flange width) and be controlled synchronously (i.e. by using E1... values in the main program).
Option 1:Using a KSD (Kuka Servo Drive) with a smaller servo motor
The smallest compatible external axis servo motor offered by KUKA is MG_8_40_45_S0 (Art No. 00-131-269).
This motor is basically a Siemens 1FK7 motor (exact part No. is 1FK7022-5AK71-1YH3-Z S24).
Looking at the 1FK7 data sheet …
There is a smaller motor (20 mm shaft height) within the range: 1FK7015-5AK7. This is the size I want to use. It also is rated for 600 VDC.
If I modify the part number to get a smaller frame size I have:
1FK7015-5AK71-1YH3-Z S24
which is shown on the Siemens website:
https://mall.industry.siemens.com/mall/en/uk/Catalog/Product/?mlfb=1FK7015-5AK71-1YH3-Z+S24... but ...
It appears some of the part numbers can't be identified within the Siemens catalogue (they are proprietary to KUKA).
"Y" "Z S24"
I have contacted Kuka and Siemens, but neither of them are cooperative and give information about the resolver type "Y" and whatever "Z S24" is.
Does anyone have any insights?
Option 2:Can anyone suggest a way of controlling the position of an external axis by reading the E1 values ($AXIS_ACT_MEAS / $AXIS_MOT ?) and using them to control an external motor via a PLC.
So far it has been hard to find info about the how virtual axes work...
Any help greatly appreciated
