QuoteIf you want to not rotate the coordinate system, you can also attach the "Dummy Axis" component. Let me know if there are issues, we fixed a bug recently that is not yet in the public release.
Well, no. In this case I DO need to rotate the coordinate system.
QuoteYou can extend both axis and Cartesian movement components to accept E1-E4.
Yes, of course !
I'm sending you my file.
Basicaly, I just need to rotate my table between milling zones orient the part in a more favorable way to the robot.
The issue is that, when I rotate the table, I don't want to set the 6 robot axis .
I could painstakingly do it by hand, reading the values from the analysis, using tags, etc... But that'll work only for a particular piece.
I want this to be parametric, because well, that's the point of using Grasshopper !
