Author Topic: Sharp corners  (Read 241 times)
zura
Sharp corners
« on: March 29, 2022, 10:06:07 AM »
Hello I wonder why it closes the 8mm round in the corner when I put in a 4mm cutter and I have a right angle in the drawing thanks
« Last Edit: March 29, 2022, 01:57:50 PM by Johannes @ Robots in Architecture »
Re: Can you help me?
« Reply #1 on: March 29, 2022, 01:57:22 PM »
Well, with a 4mm diameter tool you are always going to produce 2mm radii for these cuts.
Additionally, the robot is by default blending motions to keep a - ideally - constant speed. If you want the robot not to blend motions, right-click a movement component (e.g. LIN) and go to Movement Interpolation and select "No Interpolation".
Note that the robot will then briefly stop at every position, so that strategy is not ideal for curves.
