Can you help me align the base ?
Started by zura, April 08, 2022, 05:21:24 PM
Previous topic
Next topic
Print
User actions
Administrator
Lead Developer
Forum User
Logged
Re: Can you help me align the base ?
May 24, 2022, 08:51:30 PM
#15
That very much depends on the application. For high-accuracy milling I usually calibrate the XYZ values of a long and a short tool (the higher the difference in length the higher the accuracy) and then use the vector to calculate the right ABC values.
I can send you the code, but to get you started you could also just send me the XYZ values of a short and a long tool and I will send you the ABC values back.
User actions
Print
Pages
1
2
Robots in Architecture Forum
KUKA|prc - parametric robot control for Grasshopper
Support
(Moderator:
User actions
Print
