I want to mill the surface of a pipe following a curve (in red), but also orient the tool towards an inner curve (in white).
If I use the white curve as the "Guide", the tool is on the wrong side (Read : inside the pipe).
I had to extend the surface of the end of the pipe outward to create the green curve to use as the "Guide".
Could there be an option to consider the "Guide" curve as a "target" rather than have the tool axis go through it ?
Secondly, my base curve is a closed curve, and I would like the last frame to be the same as the first so that the tool goes all around the curve, and not stop one step before the end.
Could there be an option added for this ?
Also, I couldn't figure up the role of the "Orient" geometry, although I see it does "something".
Is there a simple drawing somewhere explaining how this "Divide curve" component works exactly ?
Thanks !
