Hello Jackson,
You're right, there was a problem with the Spline command - it was generating code, but the visualization made issues with the previous member version. If you go into the Member Section, I've uploaded a new version of KUKA|prc dated today. There is still one remaining issue with the smooth simulation (jumps back to the start point) which I'll hopefully have the time to solve over the weekend. Attached to this post is a GH file that shows you how to use the Spline component - once the remaining issues are solved I'll upload a full example into the Tutorial section.
Regarding the crash: That is strange, I've crashed Rhino and Grasshopper in all imaginable ways while working on KUKA|prc but never had a crash that forced me to reboot, at most Rhino just quit and asked me to send an error report.
And one more thing: The main advantage of the Spline command is that you need relatively few points to define a complex curve that the robot can follow quite quickly. A long series of points may negate the advantages.
Association for Robots in Architecture
