KUKA|prc Installation Problem
Started by ash_r, June 28, 2016, 12:49:03 PM
ash_r
Hello I attend University of Arizona,
we just got a KR 10 R 900 kuka and have a license for PRC which I successfully installed according to the message that popped up. Working with the head of of our Fabrication Lab, I can't seem to even getting working with some sample files. These error messages appear, thank you for any direction you may be able to offer.
First of all sorry for the inconvenience! I don't think that it's related to the licensing, as a missing license would still show the components, they just would not work. This way, we don't ruin files when you e.g. pass a Grasshopper definition to someone with a non-member versions.
Anyway, the error seems to imply that the components are missing, if you go into Grasshopper and then File/Special Folders/Component Folder there should be 2 files with KUKAprc in the filename, and 2 with Oxyplot.
I've recently seen a problem where multiple accounts where in use on a PC and the installer put the components into the folder of the administrator, rather than the user.
If the files are missing, I would suggest running the setup again and specifying an easily reachable folder (e.g. Desktop) and then to manually copy the files into the components folder. After a Rhino restart, KUKA|prc should show up.
Let me know if that helped!
P.S.: I've also unlocked the member section for you, you can now access the Rob|Arch eBooks, the new member versions of PRC etc.
ash_r
Hey Johannes,
Thank you for unlocking that stuff... The re-install worked!
Excited to dive into it more now, and look through the rest of the stuff on the site.
Thanks!
Awesome, don't hesitate to ask if you run into any more issues!
I've renamed the topic so that it's easier to find for people with similar issues, I hope you don't mind!
