Author Topic: different orientation of Plane output in Analysis?  (Read 3917 times)
AiSard
« on: September 12, 2016, 08:32:57 AM »
Not sure if I'm missing something, a bug, or a hold-over from older versions:
Plane output from the Analysis component isn't the same as Plane input (in LinMove for instance).
Seems the tool direction isn't the same?
Edit: seems to happen when the input is through AxisMove
« Last Edit: September 12, 2016, 08:34:44 AM by AiSard »
Re: different orientation of Plane output in Analysis?
« Reply #1 on: September 12, 2016, 07:12:20 PM »
Hmm... Can you send me an example?
AiSard
« Reply #2 on: September 13, 2016, 07:52:23 AM »
If the input is a Line Move, everything works as expected
if the input is Axis Move, re-inputting the plane as a Line Move input gives a different result.
