Author Topic: Video Tutorial - Pick & Place Part 1  (Read 7363 times)
singline
« on: February 09, 2017, 02:47:52 PM »
In this robotics tutorial I go through the basics of setting up a simple pick and place command script for a KUKA robot.
Tutorial here: http://bit.ly/KUKA_PickPlace
« Last Edit: February 09, 2017, 02:50:13 PM by singline »
Cian
Re: Video Tutorial - Pick & Place Part 1
« Reply #1 on: March 07, 2018, 03:24:31 PM »
I've been following your tutorials and think they're great. I successfully followed the draw/engrave tutorial and was able to replicate what you had done and then change the parameters to suit the robot I am working with (KR6 r900). However when I follow this tutorial (pick and place prt 1) my simulation robot does not generate and I can't test/simulate the script. I have tested to ensure the prc is still working in the grasshopper document from the drawing tutorial and it is.
I am new to grasshopper though I could be missing something.
Any ideas why this might be happening and how to troubleshoot?
I'm using Rhino 6 and KUKA|prc (TRIAL)
Any help you can give with this would be much appreciated.
Thanks
« Reply #2 on: March 07, 2018, 05:00:06 PM »
I'm not the creator of the tutorial, but it does seem more like a technical issue.
When you say that your simulation does not "generate", do you mean that it does not create the *.src file, or that there is no robot?
Do you get any error message? These are the small message balloons in the upper corner of the component, you can left-click them.
singline
« Reply #3 on: March 08, 2018, 12:34:41 PM »
Hi Cian,
Really glad you find the video tutorials helpful.
Would you be able to upload your gh and 3dm (if you're referencing any data from rhino) so I can have a quick look?
danhantaohomemas
  • New Forum User
  • Artchiture design with solid surface & quartz
    • homemas
« Reply #4 on: August 05, 2020, 08:39:01 AM »
Lucky, I found this tutorial video. This is my first time participating in a forum full of novelty and robotics techniques
singline
« Reply #5 on: August 06, 2020, 06:04:48 PM »
Welcome Dan!
