Author Topic: KUKA|prc 2 crash when opening KUKA|prc CORE settings  (Read 588 times)
PetterJhon
« on: July 20, 2019, 10:34:24 AM »
Hello everyone,,
Steps to reproduce:
 1. Open Rhino.
 2. Open Grasshopper.
 3. Create a new KUKA|prc core module. (for KUKA|prc2)
 4. Right click module -> Open KUKA|prc Settings
Behavior:
 1. Rhino and Grasshopper crashes and quits.
Expected behavior:
 1. No crash.
I suspect this is a local issue, as otherwise it's a pretty major bug. KUKA|prc version is KUKAprcNEWsetup_2015_09_27. License is for University of Sydney. How can I get a better error log to debug this issue? Alternatively, is there another way I can access those settings without going through the Grasshopper interface?
« Last Edit: July 31, 2019, 09:20:57 AM by Johannes @ Robots in Architecture »
Re: KUKA|prc 2 crash when opening KUKA|prc CORE settings
« Reply #1 on: July 22, 2019, 07:35:19 AM »
The University of Sydney is a member, is there a reason why you are using a software version that is several years out of date?
Usually, that problem happens when people don't use the installer but just copy the files with KUKA|prc in the name, forgetting the OxyPlot library. Or maybe you cleaned up your components folder a bit too much?
That is the reason why KUKA|prc V3 now uses its own folder!
Hope that helps, if not let me know!
