Author Topic: Homebrew Controller  (Read 1437 times)
Ryan3
  • New Forum User
Homebrew Controller
« on: July 27, 2020, 05:54:18 AM »
Once I finish demonstrate 8 axis Milling mysacstate with RM, my next task is to build my own controller for 6 axis robot. Currently available controller for homebrew are MAch3, EMC2, and LNC 6 axis myochsner controller. And after that I might need PRC's help for post-processor and maybe build a homebrew robot as well.
Any advice or suggestions are welcome.
Thanks in advance.
« Last Edit: August 25, 2020, 05:43:47 PM by Ryan3 »
Re: Homebrew Controller
« Reply #1 on: July 27, 2020, 08:22:16 AM »
Sure, with similar kinematics as KUKA you could use KUKA|prc. The member version can also output toolpaths e.g. as CSV (actually for KUKA CAMRob) or a G-Code dialect for KUKA.CNC, so it should be relatively straightforward to put it into a format your CNC controller may be able to read.
