iiwa 7th axis algorithm?
Started by evo85210, March 18, 2019, 09:44:20 AM
Previous topic
Next topic
Print
User actions
evo85210
Robots in Architecture Members
Forum User
Logged
Just wondering if anyone is using iiwa with PRC?
I've been setting the 7th axis (E1), by using galapagos by minimizing the run time and it works fine.
but as the project gets more complicated, the longer it takes to calculate the optimal angle.
Currently my project have 5129 targets, having to provide and calculate a E1 for every target is proving to be too time consuming.
So i'm wondering if anyone have another solution?
Administrator
Lead Developer
Forum User
Logged
Re: iiwa 7th axis algorithm?
March 18, 2019, 11:31:05 PM
#1
What parameters are you optimizing for? I had some success having the additional axis to face away from the target, similar to
https://forum.robotsinarchitecture.org/index.php/topic,822.0.html
But of course that cannot optimize for collisions etc.
Maybe you can constrain it so that it only optimizes the positions that have problems?
All of that is very application-specific, which is why we don't have an automatic solver for it at the moment. But any ideas are welcome!
evo85210
Forum User
Logged
March 27, 2019, 03:45:11 PM
#2
So basically run the iiwa like a 6 axis robot, and only rotate the 7th when there's a problem.
does analysis component tell me which targets have problems? or I'd have to check that manually?
side question: is there any simple HRC demo programs? like run a straight line and if it detects it bumped into something, it stops?
Administrator
Lead Developer
Forum User
Logged
March 27, 2019, 04:49:56 PM
#3
It should tell you that, yes. Consider disabling the interpolation to get less values (but also a bit less simulation accuracy).
User actions
Print
Pages
1
Robots in Architecture Forum
KUKA|prc - parametric robot control for Grasshopper
Support
(Moderator:
User actions
Print
