KUKA|prc User Interface Error
Started by utsoa, March 24, 2025, 07:51:21 PM
utsoa
Ok. I ran the "SimpleDemo.exe" file and received a .NET v6.0 error. I installed .NET v6 and can see the OxyPlot SimpleDemo window.
Running the GrasshopperDeveloperSettings shows there are no folders in there and COFF disabled.
utsoa
#16
Update > I've eliminated all versions of .NET from my system and now installed only the ".NET Desktop Runtime 8.0.15" from https://dotnet.microsoft.com/en-us/download/dotnet/8.0 to support Rhino3D along with a Registry entry per this page: https://www.rhino3d.com/en/docs/guides/netcore/  Rhino3D is up and running.
I'm using the contents of the KUKAprcGH directory copied from a system that has the KUKAprc plugin working. Now, when running Grasshopper on my system, KUKAprc IS working.
Note: .NET 7.x has vulnerabilities as pinpointed by our Information Security Office and have had to move away from it to .NET 8 which is the reason for the https://www.rhino3d.com/en/docs/guides/netcore/ page being posted. And nothing is installed in the Rhino3D PackageManager.
Proof of concept: I replaced the original three OxyPlot files within the KUKAprcGH directory with the new OxyPlot files sent earlier in this thread, which did throw the User Interface Error again. Swapping the OxyPlot files back to the origin allows the KUKAprc plugin to work.
Ok. This is where I've landed so far. Will keep you posted with any new developments.
Thanks a lot for sharing the solution, I'm glad that it's working now!
